跳转到主内容
加入维修社区 - 创建账户
Disassembling Nokia 3395 Inner Components
你所需要的
  1. Disassembling Nokia 3395 Inner Components, Back Case: 步骤 1 中的图像 1,3 Disassembling Nokia 3395 Inner Components, Back Case: 步骤 1 中的图像 2,3 Disassembling Nokia 3395 Inner Components, Back Case: 步骤 1 中的图像 3,3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    询问修复机器人
    添加评论
  2. Disassembling Nokia 3395 Inner Components, Battery: 步骤 2 中的图像 1,2 Disassembling Nokia 3395 Inner Components, Battery: 步骤 2 中的图像 2,2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    询问修复机器人
    添加评论
  3. Disassembling Nokia 3395 Inner Components, Front Case: 步骤 3 中的图像 1,2 Disassembling Nokia 3395 Inner Components, Front Case: 步骤 3 中的图像 2,2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    询问修复机器人
    添加评论
  4. Disassembling Nokia 3395 Inner Components, Screen: 步骤 4 中的图像 1,2 Disassembling Nokia 3395 Inner Components, Screen: 步骤 4 中的图像 2,2
    • Remove six T6 screws.
    询问修复机器人
    添加评论
  5. Disassembling Nokia 3395 Inner Components: 步骤 5 中的图像 1,2 Disassembling Nokia 3395 Inner Components: 步骤 5 中的图像 2,2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    询问修复机器人
    添加评论
  6. Disassembling Nokia 3395 Inner Components, Logic Board: 步骤 6 中的图像 1,2 Disassembling Nokia 3395 Inner Components, Logic Board: 步骤 6 中的图像 2,2
    • Remove logic board as shown.
    询问修复机器人
    添加评论
  7. Disassembling Nokia 3395 Inner Components, Inner Components: 步骤 7 中的图像 1,1
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
    询问修复机器人
    添加评论
  8. Disassembling Nokia 3395 Inner Components: 步骤 8 中的图像 1,2 Disassembling Nokia 3395 Inner Components: 步骤 8 中的图像 2,2
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
    询问修复机器人
    添加评论
  9. Disassembling Nokia 3395 Inner Components: 步骤 9 中的图像 1,1
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    询问修复机器人
    添加评论
  10. Disassembling Nokia 3395 Inner Components: 步骤 10 中的图像 1,2 Disassembling Nokia 3395 Inner Components: 步骤 10 中的图像 2,2
    • Audio speaker.
    询问修复机器人
    添加评论
  11. Disassembling Nokia 3395 Inner Components: 步骤 11 中的图像 1,2 Disassembling Nokia 3395 Inner Components: 步骤 11 中的图像 2,2
    • SIM card reader.
    询问修复机器人
    添加评论
  12. Disassembling Nokia 3395 Inner Components: 步骤 12 中的图像 1,2 Disassembling Nokia 3395 Inner Components: 步骤 12 中的图像 2,2
    • Vibrating unit.
    询问修复机器人
    添加评论
  13. Disassembling Nokia 3395 Inner Components: 步骤 13 中的图像 1,2 Disassembling Nokia 3395 Inner Components: 步骤 13 中的图像 2,2
    询问修复机器人
    添加评论
  14. Disassembling Nokia 3395 Inner Components: 步骤 14 中的图像 1,2 Disassembling Nokia 3395 Inner Components: 步骤 14 中的图像 2,2
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Nico Lee
于04/19/10注册
83 声望
创作了6篇指南
团队
Cal Poly, Team 30-41, Garner Spring 2010 Cal Poly, Team 30-41, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G41
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 36
总计 3,338
