跳转到主内容
Nokia 3100b Microphone Replacement
你所需要的
  1. Nokia 3100b Microphone Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure your phone is turned off.
  2. Nokia 3100b Microphone Replacement: 步骤 2 中的图像 1,1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Microphone Replacement, SIM Card: 步骤 3 中的图像 1,1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Microphone Replacement: 步骤 4 中的图像 1,1
    • Retrieve your SIM card.
  5. Nokia 3100b Microphone Replacement, Microphone: 步骤 5 中的图像 1,1
    • Press the black tabs to release the front cover from the phone.
  6. Nokia 3100b Microphone Replacement: 步骤 6 中的图像 1,1
    • Remove the front cover from the phone.
    • Set the front cover as indicated, aside.
  7. Nokia 3100b Microphone Replacement: 步骤 7 中的图像 1,2 Nokia 3100b Microphone Replacement: 步骤 7 中的图像 2,2
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  8. Nokia 3100b Microphone Replacement: 步骤 8 中的图像 1,3 Nokia 3100b Microphone Replacement: 步骤 8 中的图像 2,3 Nokia 3100b Microphone Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Note the location of the microphone.
    • Use tweezers to remove the microphone from the phone's base.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
另外一个人完成了本指南。
Sterling Fuentes
于04/09/10注册
130 声望
创作了8篇指南
团队
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G64
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,217
