跳转到主内容
加入维修社区 - 创建账户
Disassembling Nokia 2366i Keypad
你所需要的
  1. Disassembling Nokia 2366i Keypad, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 2366i Keypad, Battery: 步骤 1 中的图像 2,2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
    询问修复机器人
  2. Disassembling Nokia 2366i Keypad: 步骤 2 中的图像 1,1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    询问修复机器人
  3. Disassembling Nokia 2366i Keypad: 步骤 3 中的图像 1,3 Disassembling Nokia 2366i Keypad: 步骤 3 中的图像 2,3 Disassembling Nokia 2366i Keypad: 步骤 3 中的图像 3,3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
    询问修复机器人
  4. Disassembling Nokia 2366i Keypad, Rear Case: 步骤 4 中的图像 1,2 Disassembling Nokia 2366i Keypad, Rear Case: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
    询问修复机器人
  5. Disassembling Nokia 2366i Keypad: 步骤 5 中的图像 1,2 Disassembling Nokia 2366i Keypad: 步骤 5 中的图像 2,2
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
    询问修复机器人
  6. Disassembling Nokia 2366i Keypad: 步骤 6 中的图像 1,2 Disassembling Nokia 2366i Keypad: 步骤 6 中的图像 2,2
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
    询问修复机器人
  7. Disassembling Nokia 2366i Keypad: 步骤 7 中的图像 1,1
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
    询问修复机器人
  8. Disassembling Nokia 2366i Keypad, Motherboard: 步骤 8 中的图像 1,2 Disassembling Nokia 2366i Keypad, Motherboard: 步骤 8 中的图像 2,2
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
    询问修复机器人
  9. Disassembling Nokia 2366i Keypad: 步骤 9 中的图像 1,2 Disassembling Nokia 2366i Keypad: 步骤 9 中的图像 2,2
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
    询问修复机器人
  10. Disassembling Nokia 2366i Keypad, Keypad: 步骤 10 中的图像 1,1
    • Place key pad in view.
    询问修复机器人
  11. Disassembling Nokia 2366i Keypad: 步骤 11 中的图像 1,2 Disassembling Nokia 2366i Keypad: 步骤 11 中的图像 2,2
    • Use your fingers to remove the keypad by carefully pulling from the top of the phone towards the bottom of the phone.
    询问修复机器人
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G14
5 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 73
总计 1,180
