跳转到主内容
Disassembling Nokia 1100b RH-36
你所需要的
  1. Disassembling Nokia 1100b RH-36, Battery Cover: 步骤 1 中的图像 1,2 Disassembling Nokia 1100b RH-36, Battery Cover: 步骤 1 中的图像 2,2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Disassembling Nokia 1100b RH-36, Battery: 步骤 2 中的图像 1,1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Disassembling Nokia 1100b RH-36, Removing Nokia 1100b RH-36 Front Cover: 步骤 3 中的图像 1,2 Disassembling Nokia 1100b RH-36, Removing Nokia 1100b RH-36 Front Cover: 步骤 3 中的图像 2,2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  4. Disassembling Nokia 1100b RH-36, Inner Casing: 步骤 4 中的图像 1,2 Disassembling Nokia 1100b RH-36, Inner Casing: 步骤 4 中的图像 2,2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
结论
6等其他人完成本指南。
JSwan
于04/12/13注册
727 声望
创作了6篇指南
团队
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G43
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,195
