跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Disassembling Nintendo DS Lite Bottom Case
你所需要的
  1. Disassembling Nintendo DS Lite Bottom Case, Nintendo DS Lite Battery Disconnect: 步骤 1 中的图像 1,1
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
  2. Disassembling Nintendo DS Lite Bottom Case: 步骤 2 中的图像 1,1
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
  3. Disassembling Nintendo DS Lite Bottom Case: 步骤 3 中的图像 1,2 Disassembling Nintendo DS Lite Bottom Case: 步骤 3 中的图像 2,2
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
  4. Disassembling Nintendo DS Lite Bottom Case, Disassembling Nintendo DS Lite Bottom Case: 步骤 4 中的图像 1,1
    • Remove the following 7 screws securing the lower case to the DS Lite:
    • 3 silver tri-wing screws (5mm long)
    • 1 black tri-wing screw (4mm)
    • 2 gold Phillips screws (4mm)
    • 1 silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
  5. Disassembling Nintendo DS Lite Bottom Case: 步骤 5 中的图像 1,1
    • Remove the plastic insert (or cartridge) from the lower slot (Slot 2).
  6. Disassembling Nintendo DS Lite Bottom Case: 步骤 6 中的图像 1,2 Disassembling Nintendo DS Lite Bottom Case: 步骤 6 中的图像 2,2
    • Flip the unit over.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they pop off easily and are difficult to reassemble. Keeping the bottom case against your workbench will help hold them in place.
  7. Disassembling Nintendo DS Lite Bottom Case: 步骤 7 中的图像 1,3 Disassembling Nintendo DS Lite Bottom Case: 步骤 7 中的图像 2,3 Disassembling Nintendo DS Lite Bottom Case: 步骤 7 中的图像 3,3
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power switch cover on the bottom case is in the off (down) position. Otherwise, the power switch cover can break the very fragile power switch upon reassembly.
结论
10等其他人完成本指南。
Brittany K
于01/21/10注册
1,484 声望
创作了4篇指南
团队
Cal Poly, Team 16-30, Maness Winter 2010 Cal Poly, Team 16-30, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G30
4 名成员
创作了24篇指南
5条评论
Not bad tutorial but I want to complain a little bit. Could you add more flashlights when you take photos of dark objects? It would make this tutorial more pleasant for viewing.
Clayton Simpson - 回复
Thank you my ds gave up last night and I want to open it and have a look 👀
Rom - 回复
This tutorial worked great for me! My sons DS got wet and I was able to successfully open and dry it out. Cleaned up with alcohol and it’s running better than ever. Grateful for you!
Angela Schlagenhaft - 回复
The tri-point Y1 screwdriver is not working for me. I have tried both Y000 and Y1.
Michael Sam - 回复
Same, I just bought the Y1 triwing screwdriver here with a digitizer for the ds lite and the screwdriver is too big.
Ian Swift -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 48
过去 30 天: 248
总计 13,687
