简介
This guide will serve as a prerequisite for most replacement guides. In order to access internal components that need replacing, the cover on the bottom of the blender base must be removed. This is a simple process that involves the removal of a total of 11 screws and 3 layers of plastic molds. The screws can be removed with a Phillips #2 screwdriver.
你所需要的
Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
即将完成!
结论
