跳转到主内容
Disassembling NEC LCD1770NX Monitor Enclosure
你所需要的
  1. Disassembling NEC LCD1770NX Monitor Enclosure, Stand: 步骤 1 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure, Stand: 步骤 1 中的图像 2,2
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 2 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 2 中的图像 2,2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 3 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 3 中的图像 2,2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 4 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 4 中的图像 2,2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 5 中的图像 1,1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 6 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 6 中的图像 2,2
    • Lift the the stand straight up to remove it.
  7. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: 步骤 7 中的图像 1,3 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: 步骤 7 中的图像 2,3 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: 步骤 7 中的图像 3,3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 8 中的图像 1,3 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 8 中的图像 2,3 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 8 中的图像 3,3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 9 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 9 中的图像 2,2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 10 中的图像 1,1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 11 中的图像 1,3 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 11 中的图像 2,3 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 11 中的图像 3,3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 12 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 12 中的图像 2,2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 13 中的图像 1,2 Disassembling NEC LCD1770NX Monitor Enclosure: 步骤 13 中的图像 2,2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
结论
3等其他人完成本指南。
John Patterson
于10/19/13注册
271 声望
创作了2篇指南
团队
Cal Poly, Team 11-36, Amido Fall 2013 Cal Poly, Team 11-36, Amido Fall 2013 的会员
CPSU-AMIDO-F13S11G36
5 名成员
创作了7篇指南
1指南评论
very helpful
Thank you
Richard Morgan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 6,262
