跳转到主内容
Disassembling Motorola i90c Keypad
你所需要的
  1. Disassembling Motorola i90c Keypad, Battery: 步骤 1 中的图像 1,3 Disassembling Motorola i90c Keypad, Battery: 步骤 1 中的图像 2,3 Disassembling Motorola i90c Keypad, Battery: 步骤 1 中的图像 3,3
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Keypad: 步骤 2 中的图像 1,3 Disassembling Motorola i90c Keypad: 步骤 2 中的图像 2,3 Disassembling Motorola i90c Keypad: 步骤 2 中的图像 3,3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Keypad, Antenna: 步骤 3 中的图像 1,2 Disassembling Motorola i90c Keypad, Antenna: 步骤 3 中的图像 2,2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Keypad, Midframe: 步骤 4 中的图像 1,3 Disassembling Motorola i90c Keypad, Midframe: 步骤 4 中的图像 2,3 Disassembling Motorola i90c Keypad, Midframe: 步骤 4 中的图像 3,3
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
  5. Disassembling Motorola i90c Keypad: 步骤 5 中的图像 1,2 Disassembling Motorola i90c Keypad: 步骤 5 中的图像 2,2
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Keypad: 步骤 6 中的图像 1,3 Disassembling Motorola i90c Keypad: 步骤 6 中的图像 2,3 Disassembling Motorola i90c Keypad: 步骤 6 中的图像 3,3
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
  7. Disassembling Motorola i90c Keypad, Logic Board: 步骤 7 中的图像 1,2 Disassembling Motorola i90c Keypad, Logic Board: 步骤 7 中的图像 2,2
    • Lift the first logic board off of the rest of the device.
  8. Disassembling Motorola i90c Keypad: 步骤 8 中的图像 1,1
    • Gently lift the second logic board from the rest of the device.
    • DO NOT force the board straight off as it could damage the ribbon cable!
  9. Disassembling Motorola i90c Keypad: 步骤 9 中的图像 1,2 Disassembling Motorola i90c Keypad: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers, carefully pull off the connector shown.
  10. Disassembling Motorola i90c Keypad, Keypad: 步骤 10 中的图像 1,3 Disassembling Motorola i90c Keypad, Keypad: 步骤 10 中的图像 2,3 Disassembling Motorola i90c Keypad, Keypad: 步骤 10 中的图像 3,3
    • Remove the keypad buttons off the front cover of the phone.
结论
Jorge
于04/14/10注册
4 声望
创作了4篇指南
团队
Cal Poly, Team 29-61, Johann Spring 2010 Cal Poly, Team 29-61, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G61
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,452
