跳转到主内容
Disassembling Motorola i850 LCD Board
你所需要的
  1. Disassembling Motorola i850 LCD Board, LCD Board: 步骤 1 中的图像 1,1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Disassembling Motorola i850 LCD Board: 步骤 2 中的图像 1,2 Disassembling Motorola i850 LCD Board: 步骤 2 中的图像 2,2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Disassembling Motorola i850 LCD Board: 步骤 3 中的图像 1,1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Disassembling Motorola i850 LCD Board: 步骤 4 中的图像 1,1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Disassembling Motorola i850 LCD Board: 步骤 5 中的图像 1,1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Disassembling Motorola i850 LCD Board: 步骤 6 中的图像 1,1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Disassembling Motorola i850 LCD Board: 步骤 7 中的图像 1,1
    • Completely remove the outer casing from the phone.
  8. Disassembling Motorola i850 LCD Board: 步骤 8 中的图像 1,2 Disassembling Motorola i850 LCD Board: 步骤 8 中的图像 2,2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Disassembling Motorola i850 LCD Board: 步骤 9 中的图像 1,1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Disassembling Motorola i850 LCD Board: 步骤 10 中的图像 1,1
    • Prop out the LCD board from the phone using your fingertips.
  11. Disassembling Motorola i850 LCD Board: 步骤 11 中的图像 1,2 Disassembling Motorola i850 LCD Board: 步骤 11 中的图像 2,2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
结论
Andrew Aw
于04/08/10注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 34-56, Forte Spring 2010 Cal Poly, Team 34-56, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G56
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 2,411
