跳转到主内容
Disassembling Motorola i850 Keypad
你所需要的
  1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: 步骤 1 中的图像 1,1
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Disassembling Motorola i850 Keypad: 步骤 2 中的图像 1,2 Disassembling Motorola i850 Keypad: 步骤 2 中的图像 2,2
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Disassembling Motorola i850 Keypad, Battery: 步骤 3 中的图像 1,1
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Disassembling Motorola i850 Keypad: 步骤 4 中的图像 1,2 Disassembling Motorola i850 Keypad: 步骤 4 中的图像 2,2
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Disassembling Motorola i850 Keypad, Keypad: 步骤 5 中的图像 1,1
    • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
  6. Disassembling Motorola i850 Keypad: 步骤 6 中的图像 1,3 Disassembling Motorola i850 Keypad: 步骤 6 中的图像 2,3 Disassembling Motorola i850 Keypad: 步骤 6 中的图像 3,3
    • Grip the device firmly with both hands and carefully open the device.
    • Warning: Interior hardware inside the device can be easily damaged.
  7. Disassembling Motorola i850 Keypad: 步骤 7 中的图像 1,2 Disassembling Motorola i850 Keypad: 步骤 7 中的图像 2,2
    • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
  8. Disassembling Motorola i850 Keypad: 步骤 8 中的图像 1,2 Disassembling Motorola i850 Keypad: 步骤 8 中的图像 2,2
    • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
  9. Disassembling Motorola i850 Keypad: 步骤 9 中的图像 1,3 Disassembling Motorola i850 Keypad: 步骤 9 中的图像 2,3 Disassembling Motorola i850 Keypad: 步骤 9 中的图像 3,3
    • Place the back of the device on your hand and flip it over with the other hand.
    • Carefully lift the device to remove interior hardware.
    • The structure of the keypad should easily be loose from flipping the device.
  10. Disassembling Motorola i850 Keypad: 步骤 10 中的图像 1,3 Disassembling Motorola i850 Keypad: 步骤 10 中的图像 2,3 Disassembling Motorola i850 Keypad: 步骤 10 中的图像 3,3
    • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
    • WARNING: The plastic keypad is sensitive and can be easily damaged.
结论
Tony Chen
于04/08/10注册
1 声望
撰写一个指南
团队
Cal Poly, Team 34-56, Forte Spring 2010 Cal Poly, Team 34-56, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G56
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,640
