跳转到主内容
Motorola V180 Connector Ribbon Replacement
你所需要的
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: 步骤 1 中的图像 1,1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: 步骤 3 中的图像 1,1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: 步骤 4 中的图像 1,1
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: 步骤 5 中的图像 1,1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: 步骤 6 中的图像 1,1
    • Use a soldering iron to detach the connector ribbon from the phone.
结论
Tyler Knisley
于05/07/10注册
1 声望
创作了7篇指南
团队
Cal Poly, Team 6-16, Maness Spring 2010 Cal Poly, Team 6-16, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G16
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,613
