跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Motorola ES400,应参考我们的维修指南
  1. Disassembling Motorola ES400, Logic Board: 步骤 1 中的图像 1,2 Disassembling Motorola ES400, Logic Board: 步骤 1 中的图像 2,2
    • Take the battery cover and battery out of the device and put the unit on its front.
  2. Disassembling Motorola ES400: 步骤 2 中的图像 1,2 Disassembling Motorola ES400: 步骤 2 中的图像 2,2
    • Remove a total of 6 T5 torx screws
  3. Disassembling Motorola ES400: 步骤 3 中的图像 1,3 Disassembling Motorola ES400: 步骤 3 中的图像 2,3 Disassembling Motorola ES400: 步骤 3 中的图像 3,3
    • After all 6 screws have been removed, start by using a plastic pry tool to separate the back panel from the side frame.
    • Continue along the side near the volume buttons slowly seperating the back panel from the frame.
    • Once the back panel has been seperated from the frame slowly take it off, being careful not to break any plastic parts/clips.
    • Keep track of your screws.
  4. Disassembling Motorola ES400: 步骤 4 中的图像 1,1
    • Remove the back panel and set it aside.
  5. Disassembling Motorola ES400: 步骤 5 中的图像 1,3 Disassembling Motorola ES400: 步骤 5 中的图像 2,3 Disassembling Motorola ES400: 步骤 5 中的图像 3,3
    • Unscrew the 2 Philips head (+) screws to remove the camera flash module.
    • This unit has a broken micro usb charging port.
  6. Disassembling Motorola ES400: 步骤 6 中的图像 1,1
    • After the camera module has been removed pull up any tape covering the digitizer flex cable.
    • Flip up the plastic lever and then slowly nudge the flex cable out of the socket.
  7. Disassembling Motorola ES400: 步骤 7 中的图像 1,1
    • Near the memory card slot on the right side carefully lift the logic board over the finger to release the logic board from the frame.
  8. Disassembling Motorola ES400: 步骤 8 中的图像 1,1
    • On the left side carefully lift the logic board over the finger to release the logic board from the frame.
  9. Disassembling Motorola ES400: 步骤 9 中的图像 1,1
    • After all the fingers and clips have been released/removed, use a plastic prying tool to carefully pry the logic board out of the frame.
  10. Disassembling Motorola ES400: 步骤 10 中的图像 1,2 Disassembling Motorola ES400: 步骤 10 中的图像 2,2
    • Slowly lift the logic board out of the frame starting at the bottom of the phone.
    • (Fingers are released shown in orange)
  11. Disassembling Motorola ES400: 步骤 11 中的图像 1,1
    • Pry off metal cap to remove shielding to access LCD flex cable.
  12. Disassembling Motorola ES400: 步骤 12 中的图像 1,2 Disassembling Motorola ES400: 步骤 12 中的图像 2,2
    • Use a flat head screwdriver to flip up the FPC connector.
    • Once the plastic flipper has been flipped, slowly nudge the flex cable out of the socket.
  13. Disassembling Motorola ES400: 步骤 13 中的图像 1,1
    • Slowly lift the LCD from the logic board
    • Be mindful of double-sided tape on the backside of the LCD holding the mainboard to the screen.
    • Always handle the LCD with care so you do not crack it or apply any finger prints to the face of the LCD
  14. Disassembling Motorola ES400: 步骤 14 中的图像 1,1
    • Lay all the parts out so you can easily see what needs replacing or repairing.
Jordan Wires
于07/28/11注册
141 声望
撰写一个指南
1指南评论
This disassembly guide was provided by Wires Computing Electronics Repair. for help with any repairs in Burlington Vermont please visit: www.wirescomputing.com
Wires Computing Repairs - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 6,170
