跳转到主内容
Disassembling Motorola Droid Camera
你所需要的
  1. Disassembling Motorola Droid Camera, Battery: 步骤 1 中的图像 1,3 Disassembling Motorola Droid Camera, Battery: 步骤 1 中的图像 2,3 Disassembling Motorola Droid Camera, Battery: 步骤 1 中的图像 3,3
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Disassembling Motorola Droid Camera: 步骤 2 中的图像 1,1
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Disassembling Motorola Droid Camera, Rear Case: 步骤 3 中的图像 1,1
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Disassembling Motorola Droid Camera: 步骤 4 中的图像 1,2 Disassembling Motorola Droid Camera: 步骤 4 中的图像 2,2
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Disassembling Motorola Droid Camera: 步骤 5 中的图像 1,2 Disassembling Motorola Droid Camera: 步骤 5 中的图像 2,2
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Disassembling Motorola Droid Camera: 步骤 6 中的图像 1,1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Disassembling Motorola Droid Camera: 步骤 7 中的图像 1,1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Disassembling Motorola Droid Camera: 步骤 8 中的图像 1,1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Disassembling Motorola Droid Camera: 步骤 9 中的图像 1,1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Disassembling Motorola Droid Camera: 步骤 10 中的图像 1,2 Disassembling Motorola Droid Camera: 步骤 10 中的图像 2,2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Disassembling Motorola Droid Camera: 步骤 11 中的图像 1,2 Disassembling Motorola Droid Camera: 步骤 11 中的图像 2,2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
  12. Disassembling Motorola Droid Camera, Speaker: 步骤 12 中的图像 1,1
    • Carefully lift and remove the speaker assembly up out of the phone.
  13. Disassembling Motorola Droid Camera, Motherboard: 步骤 13 中的图像 1,3 Disassembling Motorola Droid Camera, Motherboard: 步骤 13 中的图像 2,3 Disassembling Motorola Droid Camera, Motherboard: 步骤 13 中的图像 3,3
    • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
    • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  14. Disassembling Motorola Droid Camera: 步骤 14 中的图像 1,1
    • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
  15. Disassembling Motorola Droid Camera: 步骤 15 中的图像 1,1
    • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  16. Disassembling Motorola Droid Camera: 步骤 16 中的图像 1,1
    • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  17. Disassembling Motorola Droid Camera: 步骤 17 中的图像 1,1
    • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
    • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
  18. Disassembling Motorola Droid Camera: 步骤 18 中的图像 1,2 Disassembling Motorola Droid Camera: 步骤 18 中的图像 2,2
    • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
    • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
    • Remove the motherboard from the phone.
  19. Disassembling Motorola Droid Camera, Camera Assembly: 步骤 19 中的图像 1,2 Disassembling Motorola Droid Camera, Camera Assembly: 步骤 19 中的图像 2,2
    • Orient the motherboard so that the camera lens is face down.
    • Disconnect the camera connector from its socket by prying it straight up with a spudger.
    • Remove the camera assembly.
  20. Disassembling Motorola Droid Camera, Disassembling Motorola Droid Camera: 步骤 20 中的图像 1,1
    • Use a flat jewelers screwdriver to gently pry up the housing surrounding the Camera lens. Pry up one side first, then the other.
    • Note the orientation of the Dimple on the side of the cover, as it will need to go on the same way during Reassembly.
  21. Disassembling Motorola Droid Camera: 步骤 21 中的图像 1,1
    • With the cover off, you can now see the top of the Lens holder, and immediately next to that the white Micro-Ball-Bearing shuttle. Normally, the Lens Holder should somewhat easily raise and lower, but if you are This far into it, chances are that it isn't moving easily.
  22. Disassembling Motorola Droid Camera: 步骤 22 中的图像 1,1
    • To lift out the Lens Holder, use a Pin to carefully lift an edge of the Lens Holder.
    • WARNING: Don't just turn over the assembly and tap it on the work surface: You can Easily lose the Micro-Ball-Bearing shuttle!!
  23. Disassembling Motorola Droid Camera: 步骤 23 中的图像 1,1
    • With the Lens holder lifted, the Micro-Ball-Bearing shuttle will simply fall into the cavity: Gently tip out the shuttle onto your work surface.
    • DON'T SNEEZE! That Micro-Ball-Bearing shuttle is quite lightweight, indeed!!
    • The CCD is at the Bottom of the Cavity: Please respect it,and dont touch it with anything dirty!!
结论
3等其他人完成本指南。
Stego
于10/08/11注册
165 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 2,805
