跳转到主内容
加入维修社区 - 创建账户
Disassembling Motorola Cliq Rear Casing
你所需要的
  1. Disassembling Motorola Cliq Rear Casing, Battery: 步骤 1 中的图像 1,2 Disassembling Motorola Cliq Rear Casing, Battery: 步骤 1 中的图像 2,2
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  2. Disassembling Motorola Cliq Rear Casing: 步骤 2 中的图像 1,2 Disassembling Motorola Cliq Rear Casing: 步骤 2 中的图像 2,2
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
  3. Disassembling Motorola Cliq Rear Casing, Rear Casing: 步骤 3 中的图像 1,3 Disassembling Motorola Cliq Rear Casing, Rear Casing: 步骤 3 中的图像 2,3 Disassembling Motorola Cliq Rear Casing, Rear Casing: 步骤 3 中的图像 3,3
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  4. Disassembling Motorola Cliq Rear Casing: 步骤 4 中的图像 1,1
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  5. Disassembling Motorola Cliq Rear Casing: 步骤 5 中的图像 1,3 Disassembling Motorola Cliq Rear Casing: 步骤 5 中的图像 2,3 Disassembling Motorola Cliq Rear Casing: 步骤 5 中的图像 3,3
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
  6. Disassembling Motorola Cliq Rear Casing: 步骤 6 中的图像 1,1
    • Carefully separate the back casing from the rest of the phone.
  7. Disassembling Motorola Cliq Rear Casing: 步骤 7 中的图像 1,2 Disassembling Motorola Cliq Rear Casing: 步骤 7 中的图像 2,2
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
  8. Disassembling Motorola Cliq Rear Casing: 步骤 8 中的图像 1,3 Disassembling Motorola Cliq Rear Casing: 步骤 8 中的图像 2,3 Disassembling Motorola Cliq Rear Casing: 步骤 8 中的图像 3,3
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
结论
2等其他人完成本指南。
Tony Tran
于04/14/13注册
69 声望
创作了8篇指南
团队
Cal Poly, Team 10-42, Amido Spring 2013 Cal Poly, Team 10-42, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G42
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 27
总计 715
