跳转到主内容
Disassembling Minolta Maxxum STsi Top Cover
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Disassembling Minolta Maxxum STsi Top Cover, Main Battery: 步骤 1 中的图像 1,1
    • Use the edge of a coin to twist open the battery compartment on the bottom of the camera. (Twist counterclockwise)
  2. Disassembling Minolta Maxxum STsi Top Cover: 步骤 2 中的图像 1,1
    • When the compartment opens, pull the AA battery out of its slot.
  3. Disassembling Minolta Maxxum STsi Top Cover, Top Cover: 步骤 3 中的图像 1,1
    • Remove the black Phillips #00 5mm screw at the bottom of the battery chamber.
    • If it is too dark to see the screw, it may help to use a flashlight.
  4. Disassembling Minolta Maxxum STsi Top Cover: 步骤 4 中的图像 1,1
    • Take out two silver Phillips #00 5.0 mm screws on each side of the viewfinder.
  5. Disassembling Minolta Maxxum STsi Top Cover: 步骤 5 中的图像 1,1
    • Open the flash and take out the silver Phillips #00 4.0 mm screw underneath it.
  6. Disassembling Minolta Maxxum STsi Top Cover: 步骤 6 中的图像 1,1
    • Open the back-cover of the camera using the back-cover release found on the lower right side of the camera.
  7. Disassembling Minolta Maxxum STsi Top Cover: 步骤 7 中的图像 1,1
    • Remove the black Phillips #00 4.0 mm screw from the inside top right section of the camera.
  8. Disassembling Minolta Maxxum STsi Top Cover: 步骤 8 中的图像 1,1
    • Remove the black Phillips #00 5.0 mm screw from the back of the film compartment.
  9. Disassembling Minolta Maxxum STsi Top Cover: 步骤 9 中的图像 1,2 Disassembling Minolta Maxxum STsi Top Cover: 步骤 9 中的图像 2,2
    • Remove the seven black Phillips #00 5.0 mm screws from the bottom panel. The bottom panel is now free to come off.
  10. Disassembling Minolta Maxxum STsi Top Cover: 步骤 10 中的图像 1,1
    • Take out two black Phillips #00 2.5 mm screws on the right side panel of the camera.
  11. Disassembling Minolta Maxxum STsi Top Cover: 步骤 11 中的图像 1,3 Disassembling Minolta Maxxum STsi Top Cover: 步骤 11 中的图像 2,3 Disassembling Minolta Maxxum STsi Top Cover: 步骤 11 中的图像 3,3
    • Starting beneath the "SPOT" button, use the round side of the metal spudger and firmly pry underneath the grey top panel of the camera. Work your way counterclockwise around the camera prying at different spots until the top panel starts to come loose. Pry all the way around until you reach the "STsi" logo.
    • This prying will not completely release the top cover. It is also necessary to take off the side panel, as explained in the next step.
  12. Disassembling Minolta Maxxum STsi Top Cover: 步骤 12 中的图像 1,2 Disassembling Minolta Maxxum STsi Top Cover: 步骤 12 中的图像 2,2
    • Be careful when removing the right side panel. There is a plastic component underneath the side panel that will come free. Note the orientation of this plastic component for reassembly because it is connected to the back-cover release switch.
    • Also be gentle when removing the top panel because it is delicate and is connected by wires.
    • Carefully remove the right side panel by grasping it at the bottom and rotating is counter-clockwise. The top panel is now free to snap off.
结论
Brady Hill
于04/23/15注册
234 声望
创作了2篇指南
团队
Cal Poly, Team 14-12, Amido Spring 2015 Cal Poly, Team 14-12, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G12
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 79
