跳转到主内容
Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case
你所需要的
  1. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: 步骤 1 中的图像 1,2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: 步骤 1 中的图像 2,2
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 步骤 2 中的图像 1,1
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 步骤 3 中的图像 1,2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 步骤 3 中的图像 2,2
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 步骤 4 中的图像 1,2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: 步骤 4 中的图像 2,2
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
结论
4等其他人完成本指南。
RoggeSound
于06/05/10注册
2,345 声望
撰写一个指南
2条评论
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - 回复
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 6,752
