跳转到主内容
简介
With this guide you can take your MM-4 from one solid brick of a speaker to four parts and a bunch of screws. This is useful if you are replacing a bad driver, or if the connector becomes damaged and you need to replace it.
  1. Turn the speaker face down, so the connector side is up. Remove the four #2 Philips screws on the back plate.
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Remove the foam insert to expose the two spade connectors.
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Turn the speaker so the grill side is up. Remove the four screws on the grill.  I had to use a t-10 Torx bit to remove them.
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Remove the four silver bolts holding the speaker in place.  These bolts also have threads inset for the grill screws to fit into. This is a pretty quick and easy teardown, not too many parts in this one.  The meyer speaker's part number is ST-164.  It's a 16 Ohm driver.
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
结论
3等其他人完成本指南。
RoggeSound
于2010年06月05日注册
2,179 信誉积分
撰写一个指南
2条评论
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - 回复
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 13
总计 6,260
