跳转到主内容
Disassembling Mercedes W123 Kick Panel
你所需要的
  1. Disassembling Mercedes W123 Kick Panel, Kick Panel: 步骤 1 中的图像 1,1
    • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
  2. Disassembling Mercedes W123 Kick Panel: 步骤 2 中的图像 1,1
    • Then remove these screws.
  3. Disassembling Mercedes W123 Kick Panel: 步骤 3 中的图像 1,2 Disassembling Mercedes W123 Kick Panel: 步骤 3 中的图像 2,2
    • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
  4. Disassembling Mercedes W123 Kick Panel: 步骤 4 中的图像 1,2 Disassembling Mercedes W123 Kick Panel: 步骤 4 中的图像 2,2
    • Now lower the panel down and rest if on the floor.
    • It can be removed full for further ease of access, depending on the job at hand.
  5. Disassembling Mercedes W123 Kick Panel: 步骤 5 中的图像 1,3 Disassembling Mercedes W123 Kick Panel: 步骤 5 中的图像 2,3 Disassembling Mercedes W123 Kick Panel: 步骤 5 中的图像 3,3
    • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
    • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
    • Heater blower motor
    • Over-voltage protection relay
    • Air-conditioning expansion valve
结论
11等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,040 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,532篇指南
一条评论
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 65
总计 13,414
