当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Start by opening the glove box.
Remove the two phillips screws in the glove box door catch, then remove it.
Gently pry apart the expansion plug in the glove box clips. There will be a row of them on top, and on the bottom.
Once you've pried it out part of the way you can pull it the rest of the way out by hand, or gently with needle nose pliers.
You can then pry the clips out of the liner. Remove them all.
Gently pry down the cover for the glove box lamp.
Now unplug the two connections from the lamp and remove the lamp housing.
Be sure to make note of the orientation of the two wires for re-installation.
Now the glove box liner will pull out by hand.
取消:我没有完成这个指南。
6等其他人完成本指南。
与1其他贡献者
于12/06/13注册
39,040 声望
创作了79篇指南
徽章: 30
+ 27更多徽章
Community
322 名成员
创作了2,541篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 81
总计 11,131
