跳转到主内容
Disassembling Marshall MS-2 Micro Amp Case Disassembly
你所需要的
  1. Disassembling Marshall MS-2 Micro Amp Case Disassembly, Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 1 中的图像 1,1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 2 中的图像 1,3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 2 中的图像 2,3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 2 中的图像 3,3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 3 中的图像 1,2 Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 3 中的图像 2,2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 4 中的图像 1,1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
结论
另外一个人完成了本指南。
MacKinley
于10/22/13注册
811 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 2,060
