跳转到主内容
Disassembling Macintosh IIsi Power Supply
你所需要的
  1. Disassembling Macintosh IIsi Power Supply, Top Case: 步骤 1 中的图像 1,2 Disassembling Macintosh IIsi Power Supply, Top Case: 步骤 1 中的图像 2,2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Power Supply: 步骤 2 中的图像 1,3 Disassembling Macintosh IIsi Power Supply: 步骤 2 中的图像 2,3 Disassembling Macintosh IIsi Power Supply: 步骤 2 中的图像 3,3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Power Supply, Floppy Drive: 步骤 3 中的图像 1,3 Disassembling Macintosh IIsi Power Supply, Floppy Drive: 步骤 3 中的图像 2,3 Disassembling Macintosh IIsi Power Supply, Floppy Drive: 步骤 3 中的图像 3,3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Power Supply: 步骤 4 中的图像 1,3 Disassembling Macintosh IIsi Power Supply: 步骤 4 中的图像 2,3 Disassembling Macintosh IIsi Power Supply: 步骤 4 中的图像 3,3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
  5. Disassembling Macintosh IIsi Power Supply, System Fan: 步骤 5 中的图像 1,1
    • The fan recieves power from two contacts on the logic board and has no connector.
  6. Disassembling Macintosh IIsi Power Supply: 步骤 6 中的图像 1,3 Disassembling Macintosh IIsi Power Supply: 步骤 6 中的图像 2,3 Disassembling Macintosh IIsi Power Supply: 步骤 6 中的图像 3,3
    • In all of the years that I have worked on this machine, I have found no good way to remove the fan.
    • The best way to start, is to push in here on the side of the fan.
    • Being careful not to exert too much force, try to push in, and wiggle the fan outward as such. (2nd Photo)
    • You can now lift the fan all the way out, and remove it.
    • The Fan Power Contacts on the Logic Board:
  7. Disassembling Macintosh IIsi Power Supply, Power Supply: 步骤 7 中的图像 1,2 Disassembling Macintosh IIsi Power Supply, Power Supply: 步骤 7 中的图像 2,2
    • To remove the power supply, squeeze these two tabs and lift the front up.
    • On the back of the power supply, there is a tab that also must be pressed to remove the power supply fully. You can then lift it out all the way. A firm tug may be necessary to seperate the power connector.
  8. Disassembling Macintosh IIsi Power Supply: 步骤 8 中的图像 1,2 Disassembling Macintosh IIsi Power Supply: 步骤 8 中的图像 2,2
    • Information on the power supply:
    • It was made by Sony in 1990, and uses a 10-Pin power connector.
结论
2等其他人完成本指南。
Chris Green
于10/11/09注册
37,197 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,516篇指南
一条评论
I was looking for the schematic for the power supply APS-06 pictured here. The information above would be a little helpful if one was really unaware of anything electromechanical,… otherwise, it’s all pretty obvious I think.
nikitesla - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 3,585
