跳转到主内容
Disassembling Macintosh IIsi Floppy Drive
你所需要的
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: 步骤 1 中的图像 1,2 Disassembling Macintosh IIsi Floppy Drive, Top Case: 步骤 1 中的图像 2,2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: 步骤 2 中的图像 1,3 Disassembling Macintosh IIsi Floppy Drive: 步骤 2 中的图像 2,3 Disassembling Macintosh IIsi Floppy Drive: 步骤 2 中的图像 3,3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 步骤 3 中的图像 1,3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 步骤 3 中的图像 2,3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: 步骤 3 中的图像 3,3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: 步骤 4 中的图像 1,3 Disassembling Macintosh IIsi Floppy Drive: 步骤 4 中的图像 2,3 Disassembling Macintosh IIsi Floppy Drive: 步骤 4 中的图像 3,3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
结论
2等其他人完成本指南。
Chris Green
于10/11/09注册
36,978 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,520篇指南
一条评论
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,758
