跳转到主内容
加入维修社区 - 创建账户
Disassembling Logitech UE MegaBoom 3 General Disassembly
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Disassembling Logitech UE MegaBoom 3 General Disassembly, General Disassembly: 步骤 1 中的图像 1,2 Disassembling Logitech UE MegaBoom 3 General Disassembly, General Disassembly: 步骤 1 中的图像 2,2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Disassembling Logitech UE MegaBoom 3 General Disassembly: 步骤 2 中的图像 1,3 Disassembling Logitech UE MegaBoom 3 General Disassembly: 步骤 2 中的图像 2,3 Disassembling Logitech UE MegaBoom 3 General Disassembly: 步骤 2 中的图像 3,3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
结论
另外一个人完成了本指南。
Anthony Miles
于09/04/23注册
1,021 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 62
