跳转到主内容
Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections
你所需要的
  1. Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections, Interior Soldered Wire Connections: 步骤 1 中的图像 1,1
    • The back panel (pictured left) has a black wire (end of wire circled red). The wire solders to the bottom right corner of the card drive.
    • The front panel (pictured right) has a black and red wire (end of wired circled green). This wire solders to a small circular spot next to where the black wire connects to the back (from above).
结论
ewkpates
于05/03/12注册
133 声望
撰写一个指南
2条评论
To open the leappad top start with, remove battery covers and the 6 screws.
The two halves slide, bottom half towards cartridge slot, to make it harder they have used double sided tape on the bottom platic tounges, so a scredriver in the bottom will be needed to prize the slide.
Lawrence - 回复
Good stuff. I'm trying to slide the back plate upward, but to no avail. You mentioned tape. Where exactly is it located?
John - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 5,938
