跳转到主内容
加入维修社区 - 创建账户
Disassembling LG Vortex
你所需要的
  1. Disassembling LG Vortex, Power down the Phone: 步骤 1 中的图像 1,1
    • Power the phone off
    • The power button is located on top of the phone
    询问修复机器人
    添加评论
  2. Disassembling LG Vortex, Remove the Back Cover: 步骤 2 中的图像 1,3 Disassembling LG Vortex, Remove the Back Cover: 步骤 2 中的图像 2,3 Disassembling LG Vortex, Remove the Back Cover: 步骤 2 中的图像 3,3
    • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
    询问修复机器人
    添加评论
  3. Disassembling LG Vortex: 步骤 3 中的图像 1,1
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Put the battery aside.
    询问修复机器人
    添加评论
  4. Disassembling LG Vortex, Unscrew the Back Frame: 步骤 4 中的图像 1,2 Disassembling LG Vortex, Unscrew the Back Frame: 步骤 4 中的图像 2,2
    • All screws are the same size screwdriver head #00
    • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in a container to ensure they aren't lost.
    添加评论
  5. Disassembling LG Vortex, Remove the Back Frame: 步骤 5 中的图像 1,3 Disassembling LG Vortex, Remove the Back Frame: 步骤 5 中的图像 2,3 Disassembling LG Vortex, Remove the Back Frame: 步骤 5 中的图像 3,3
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Jen
于02/13/14注册
40 声望
创作了3篇指南
团队
Ohio State, Team 1-3, Buehl Spring 2014 Ohio State, Team 1-3, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G3
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 55
总计 4,928
