跳转到主内容
Disassembling LG VX8300 Body
你所需要的
  1. Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: 步骤 1 中的图像 1,3 Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: 步骤 1 中的图像 2,3 Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: 步骤 1 中的图像 3,3
    • Power off the device by holding down the red button labeled PWR.
    • Be sure that the phone is powered off before touching the battery to avoid danger.
    • Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
  2. Disassembling LG VX8300 Body: 步骤 2 中的图像 1,2 Disassembling LG VX8300 Body: 步骤 2 中的图像 2,2
    • Place your finger into the semicircle gap on top of the battery.
    • Apply force downward and out, so the battery pops out of the phone.
  3. Disassembling LG VX8300 Body: 步骤 3 中的图像 1,3 Disassembling LG VX8300 Body: 步骤 3 中的图像 2,3 Disassembling LG VX8300 Body: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Locate the two rubber pads covering the screws at the top of the phone near the hinge.
    • Use tweezers to lift and remove the rubber pads.
  4. Disassembling LG VX8300 Body: 步骤 4 中的图像 1,2 Disassembling LG VX8300 Body: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove all four 3mm screws from the back of the phone.
  5. Disassembling LG VX8300 Body: 步骤 5 中的图像 1,2 Disassembling LG VX8300 Body: 步骤 5 中的图像 2,2
    • Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
    • Remove the casing after it has been detached. The logic board is now fully accessible.
    • Once the body case is removed, the volume and camera buttons move freely. Ensure all loose pieces remain accounted for.
结论
2等其他人完成本指南。
nvalm
于03/23/15注册
448 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-7, Duarte Spring 2015 UMass Dartmouth, Team 3-7, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G7
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 792
