跳转到主内容
Disassembling Krups 963 Top Cover
你所需要的
  1. Disassembling Krups 963 Top Cover, Removing Bottom Screws: 步骤 1 中的图像 1,1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Disassembling Krups 963 Top Cover: 步骤 2 中的图像 1,1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Disassembling Krups 963 Top Cover: 步骤 3 中的图像 1,1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Disassembling Krups 963 Top Cover, Disassembling Krups 963 Top Cover: 步骤 4 中的图像 1,1
    • Remove the three 60mm Phillips size 0 screws holding the top cover on.
  5. Disassembling Krups 963 Top Cover: 步骤 5 中的图像 1,1
    • Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
    • Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
  6. Disassembling Krups 963 Top Cover: 步骤 6 中的图像 1,1
    • Remove the grey plastic ring from the rim of the filter basket holder.
  7. Disassembling Krups 963 Top Cover: 步骤 7 中的图像 1,1
    • Lift and remove the top black plastic cover from the machine.
结论
3等其他人完成本指南。
Wyatt Hall
于10/13/14注册
842 声望
创作了7篇指南
团队
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G25
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 3,449
