跳转到主内容
Disassembling Kodak Advantix F350 Front Cover
你所需要的
  1. Disassembling Kodak Advantix F350 Front Cover, Back Cover: 步骤 1 中的图像 1,1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Front Cover: 步骤 2 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover: 步骤 2 中的图像 2,2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Front Cover: 步骤 3 中的图像 1,3 Disassembling Kodak Advantix F350 Front Cover: 步骤 3 中的图像 2,3 Disassembling Kodak Advantix F350 Front Cover: 步骤 3 中的图像 3,3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Front Cover: 步骤 4 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover: 步骤 4 中的图像 2,2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Front Cover: 步骤 5 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Front Cover: 步骤 6 中的图像 1,3 Disassembling Kodak Advantix F350 Front Cover: 步骤 6 中的图像 2,3 Disassembling Kodak Advantix F350 Front Cover: 步骤 6 中的图像 3,3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
  7. Disassembling Kodak Advantix F350 Front Cover, Front Cover: 步骤 7 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover, Front Cover: 步骤 7 中的图像 2,2
    • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
    • The first 2 are located on the bottom of the camera.
    • The last screw is located behind the flash module.
    • Turn the camera on, and raise the flash module to locate the flash module screw.
  8. Disassembling Kodak Advantix F350 Front Cover: 步骤 8 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover: 步骤 8 中的图像 2,2
    • Remove the 2 screws at the base of the camera housing.
    • Use the Phillips #00 Precision Screwdriver and remove the screws.
    • Repeat this process for the screw behind the flash module.
  9. Disassembling Kodak Advantix F350 Front Cover: 步骤 9 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover: 步骤 9 中的图像 2,2
    • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
  10. Disassembling Kodak Advantix F350 Front Cover: 步骤 10 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover: 步骤 10 中的图像 2,2
    • Remove the flash cover.
    • Remove the flash module by twisting it up and outward of the camera housing.
    • The cover can now be be removed.
  11. Disassembling Kodak Advantix F350 Front Cover: 步骤 11 中的图像 1,2 Disassembling Kodak Advantix F350 Front Cover: 步骤 11 中的图像 2,2
    • Remove the film door lever.
    • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
    • Using a plastic opening tool, gently pry the switch upwards to remove it.
  12. Disassembling Kodak Advantix F350 Front Cover: 步骤 12 中的图像 1,1
    • Open the battery door by pushing the lever towards the arrow indicated.
  13. Disassembling Kodak Advantix F350 Front Cover: 步骤 13 中的图像 1,3 Disassembling Kodak Advantix F350 Front Cover: 步骤 13 中的图像 2,3 Disassembling Kodak Advantix F350 Front Cover: 步骤 13 中的图像 3,3
    • Remove the front cover.
    • Insert your thumb in the film hole and gently pry the bottom loose.
    • Once the front is loose, gently pull it out.
结论
团队
UW Stout, Team 1-2, Zhou Fall 2011 UW Stout, Team 1-2, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 835
