跳转到主内容
Disassembling Kodak Advantix F350 Back Cover
你所需要的
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: 步骤 1 中的图像 1,1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: 步骤 2 中的图像 1,2 Disassembling Kodak Advantix F350 Back Cover: 步骤 2 中的图像 2,2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: 步骤 3 中的图像 1,3 Disassembling Kodak Advantix F350 Back Cover: 步骤 3 中的图像 2,3 Disassembling Kodak Advantix F350 Back Cover: 步骤 3 中的图像 3,3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: 步骤 4 中的图像 1,2 Disassembling Kodak Advantix F350 Back Cover: 步骤 4 中的图像 2,2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: 步骤 5 中的图像 1,2 Disassembling Kodak Advantix F350 Back Cover: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: 步骤 6 中的图像 1,3 Disassembling Kodak Advantix F350 Back Cover: 步骤 6 中的图像 2,3 Disassembling Kodak Advantix F350 Back Cover: 步骤 6 中的图像 3,3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
结论
另外一个人完成了本指南。
David Cottrell
于10/04/11注册
103 声望
创作了5篇指南
团队
UW Stout, Team 1-2, Zhou Fall 2011 UW Stout, Team 1-2, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 1,148
