跳转到主内容
加入维修社区 - 创建账户
Disassembling Kitchenware Rival Coffee Maker
你所需要的
  1. Disassembling Kitchenware Rival Coffee Maker, Rival Single Cup Coffee Maker: 步骤 1 中的图像 1,1
    • Make sure the coffee maker is unplugged before proceeding.
  2. Disassembling Kitchenware Rival Coffee Maker, Unscrewing  Metal Base: 步骤 2 中的图像 1,1
    • Locate and unscrew the 3 8mm Three-pronged Y screws at the bottom of the coffee maker base.
  3. Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: 步骤 3 中的图像 1,3 Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: 步骤 3 中的图像 2,3 Disassembling Kitchenware Rival Coffee Maker, Removing Metal Base: 步骤 3 中的图像 3,3
    • Locate the white securing tab on the front rounded metal base. Push up on the plastic with the tip of your thumbs until the metal base is clear from the tab.
    • Remove the metal base from the coffee maker.
  4. Disassembling Kitchenware Rival Coffee Maker, Removing Power Cable Screws: 步骤 4 中的图像 1,2 Disassembling Kitchenware Rival Coffee Maker, Removing Power Cable Screws: 步骤 4 中的图像 2,2
    • Remove the two 13mm Phillips screws to release the power cord.
    • Remove the white cap from the screw holder.
  5. Disassembling Kitchenware Rival Coffee Maker, Removing Bottom Chassis Screws: 步骤 5 中的图像 1,2 Disassembling Kitchenware Rival Coffee Maker, Removing Bottom Chassis Screws: 步骤 5 中的图像 2,2
    • Remove the two 8mm Phillips screws from the metal chassis.
    • Remove the two black screw caps.
  6. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Power Button: 步骤 6 中的图像 1,1
    • Remove the 7mm Phillips screw from the power button.
  7. Disassembling Kitchenware Rival Coffee Maker, Removing Power Button: 步骤 7 中的图像 1,2 Disassembling Kitchenware Rival Coffee Maker, Removing Power Button: 步骤 7 中的图像 2,2
    • Use a spudger or a flat head screwdriver to pull the white tab away from the power button body.
    • Pull the power button to the left of the tab until it is free from the tab. Then push the power button through the coffee makers body and let it sit inside the coffee makers body.
  8. Disassembling Kitchenware Rival Coffee Maker, Removing Power button from Cable: 步骤 8 中的图像 1,1
    • Remove the 7mm Phillips screw from the motherboard of the power button.
    • Pull the white plastic body away from the logic board.
  9. Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: 步骤 9 中的图像 1,3 Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: 步骤 9 中的图像 2,3 Disassembling Kitchenware Rival Coffee Maker, Unscrewing Bottom Half Plastic: 步骤 9 中的图像 3,3
    • Remove the 4 13mm Phillips screws from the four corners of the case to release the bottom half of the coffee maker.
    • These screws are very deep and you may need a longer thinner screwdriver for it.
  10. Disassembling Kitchenware Rival Coffee Maker: 步骤 10 中的图像 1,3 Disassembling Kitchenware Rival Coffee Maker: 步骤 10 中的图像 2,3 Disassembling Kitchenware Rival Coffee Maker: 步骤 10 中的图像 3,3
    • Tilt the bottom half of the coffee maker forward.
    • Pull up until it is free from the top half while feeding the power cable down through the plastic body.
    • Be gentle while removing the bottom half as the cables to the power button are very fragile.
结论
4等其他人完成本指南。
Michael
于08/17/13注册
199 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 1,925
