你所需要的
打开 Keurig 的顶盖。
用手抓住顶盖的其中一个连接臂直接向外拉。 这将需要大力一些,以挣脱插销。 一侧的连接臂脱离后,另一条连接臂也重复这个过程。
将 Keurig 以竖直方向摆放,并让正面对着你。
从 Keurig 顶部拉下盖子。稍稍用力就能轻而易举的拿下。
Not coming off easily. Pull toward front a little helps.
There are two plastic latching tabs that hold down the back of this cover, about 5/8 inch in from either side. It should be possible to locate them by probing along the back parting line with a thin-blade screwdriver and release them by pressing forward. Or apply excessive force like I did and break them off.
Thx for warning, Lytle!
The two tabs face forward so pushing on them won't help. Instead, push the cover BACK while wiggling its sideways. The cover may stick a little at first. You can pry it up SLIGHTLY but once a small gap opens, quit prying...just push back and wiggle sideways until the cover moves back about quarter inch and comes loose.
牢牢抓住软管并将其从塑料喷嘴上拉出。
Before pulling, you can see if this portion of the tube is clogged. If clogged at the other end, you may be wasting time going further. See comments at the last step.
Maybe, but it’s unlikely to be the case. The transition from roomy hose to cramped needle outlets is where syphoned up coffee grounds get caked up. And you might not see it. I squeezed the hose at the union a few times and that made black crud come loose. A visual inspection only would not have shown that.
Our unit's hose end was secured with a plastic zip tie that had to be cut off. When replacing the hose, a new zip tie was required.
DO NOT cut it. Just slide the zip tie with your fingers. Then when reattaching the hose, put on hose first then shimmy zip tie back over union.
Thanks so much Sr Sr Jr for both comments here!
要重新组装您的设备,请按照相反的顺序执行这些指示。
由衷感谢以下译者:
100%
Ou Hiroshizon正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
This step isn’t necessary.
Senior Senior, Jr. - 回复
Thank you!! Since I sure cldnt get both arms to come off!
shari_thompson1 -
I cannot get the arms to come off at all!
Susan Klipfel - 回复
