跳转到主内容
Disassembling Keurig Mini B-31 Top
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Disassembling Keurig Mini B-31 Top, Top: 步骤 1 中的图像 1,3 Disassembling Keurig Mini B-31 Top, Top: 步骤 1 中的图像 2,3 Disassembling Keurig Mini B-31 Top, Top: 步骤 1 中的图像 3,3
    • Open the top lid of the Keurig.
    • Pull directly outwards on one of the arms that holds the top lid in place. It will take some force to get the arm off the peg. Once one side is off, repeat the process on the second arm.
  2. Disassembling Keurig Mini B-31 Top: 步骤 2 中的图像 1,1
    • Lay the Keurig on its back with the water reservoir pointing away from you.
  3. Disassembling Keurig Mini B-31 Top: 步骤 3 中的图像 1,1
    • Avoid the top needle as it may puncture your hand.
    • Unscrew the two 9mm #1 Philips screws that hold the top plastic cover in place.
  4. Disassembling Keurig Mini B-31 Top: 步骤 4 中的图像 1,1
    • Set the Keurig in an upright position with the front side facing you.
    • Pull the cover off the top of the Keurig. It should come off easily with little force.
  5. Disassembling Keurig Mini B-31 Top: 步骤 5 中的图像 1,1
    • Firmly grasp the hose and pull it off of the plastic nozzle.
结论
Andrew Adriance
于01/14/14注册
1,914 声望
创作了7篇指南
团队
Cal Poly, Team 17-1, Forte Winter 2014 Cal Poly, Team 17-1, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G1
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 79
