跳转到主内容
Disassembling Kenwood TM-241a Main body
你所需要的
  1. Disassembling Kenwood TM-241a Main body, Main body: 步骤 1 中的图像 1,3 Disassembling Kenwood TM-241a Main body, Main body: 步骤 1 中的图像 2,3 Disassembling Kenwood TM-241a Main body, Main body: 步骤 1 中的图像 3,3
    • Push down on the tab that locks the power connection together, and slide the two connectors apart.
    • Unscrew the antenna downlead from the antenna pigtail coming out of the radio, and pull the two apart.
    • Unscrew the microphone connector from the front panel of the radio, and pull it out.
  2. Disassembling Kenwood TM-241a Main body: 步骤 2 中的图像 1,2 Disassembling Kenwood TM-241a Main body: 步骤 2 中的图像 2,2
    • Using a #1 phillips screwdriver, remove the two screws that secure the top cover to the radio.
    • Do the same to the two screws on the bottom.
  3. Disassembling Kenwood TM-241a Main body: 步骤 3 中的图像 1,3 Disassembling Kenwood TM-241a Main body: 步骤 3 中的图像 2,3 Disassembling Kenwood TM-241a Main body: 步骤 3 中的图像 3,3
    • There are two tabs that sit underneath the sides of the face plate. They have a tendency to break out the plastic over top of them while removing the covers. To help prevent this, push inward on the side of the cover, just behind the face plate as you take off the covers.
    • Lift up on the rear of the top cover, and slide it towards the back of the radio to disengage the three tabs at the front.
    • Repeat for the bottom cover of the radio.
结论
Josh
于03/22/13注册
707 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 527
