简介
This guide will show which screws need to be taken out to allow the control board to be removed from the radio. The control board must be taken out to replace a dead backup battery.
  1. Push down on the tab that locks the power connection together, and slide the two connectors apart. Unscrew the antenna downlead from the antenna pigtail coming out of the radio, and pull the two apart. Unscrew the microphone connector from the front panel of the radio, and pull it out.
    • Push down on the tab that locks the power connection together, and slide the two connectors apart.
    • Unscrew the antenna downlead from the antenna pigtail coming out of the radio, and pull the two apart.
    • Unscrew the microphone connector from the front panel of the radio, and pull it out.
  2. Using a #1 phillips screwdriver, remove the two screws that secure the top cover to the radio. Do the same to the two screws on the bottom.
    • Using a #1 phillips screwdriver, remove the two screws that secure the top cover to the radio.
    • Do the same to the two screws on the bottom.
  3. There are two tabs that sit underneath the sides of the face plate.  They have a tendency to break out the plastic over top of them while removing the covers.  To help prevent this, push inward on the side of the cover, just behind the face plate as you take off the covers. Lift up on the rear of the top cover, and slide it towards the back of the radio to disengage the three tabs at the front. Repeat for the bottom cover of the radio.
    • There are two tabs that sit underneath the sides of the face plate. They have a tendency to break out the plastic over top of them while removing the covers. To help prevent this, push inward on the side of the cover, just behind the face plate as you take off the covers.
    • Lift up on the rear of the top cover, and slide it towards the back of the radio to disengage the three tabs at the front.
    • Repeat for the bottom cover of the radio.
  4. On the left side of the screen, gently pull on the tuning knob, separating it from the radio. The upper knob on the right is the volume.  Gently pull it away from the radio to remove it. The lower knob on the right is the squelch knob.  Remove it in the same way as the other two knobs.
    • On the left side of the screen, gently pull on the tuning knob, separating it from the radio.
    • The upper knob on the right is the volume. Gently pull it away from the radio to remove it.
    • The lower knob on the right is the squelch knob. Remove it in the same way as the other two knobs.
    • Set the three knobs aside, so they can be put back on later.
    • The volume and the squelch knob are the same part and can be interchanged.
  5. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Below where the tuning knob was, there is a 7/16" nut that helps to secure the face plate to the radio.  This needs to be removed to allow the face plate to be taken off. Behind the nut is a small washer.  Be sure to pull it off as well and set the two aside so they do not get lost.
    • Below where the tuning knob was, there is a 7/16" nut that helps to secure the face plate to the radio. This needs to be removed to allow the face plate to be taken off.
    • Behind the nut is a small washer. Be sure to pull it off as well and set the two aside so they do not get lost.
  7. Below the jack for the microphone, there is a nut.  This is not a standard hex headed nut.  It has four notches around the edge of the nut.  A pair of snap ring pliers works well to engage the notches, allowing you to remove the nut.
    • Below the jack for the microphone, there is a nut. This is not a standard hex headed nut. It has four notches around the edge of the nut. A pair of snap ring pliers works well to engage the notches, allowing you to remove the nut.
  8. There is a screw on each of the four sides (top, bottom, and each side) of the face plate. Removing these screws will allow the face plate to be removed from the radio body. There are two types of screws used in this step.  The screws on the top and bottom are different from the screws from the sides.  Note which style of screw is used on each side. There are two types of screws used in this step.  The screws on the top and bottom are different from the screws from the sides.  Note which style of screw is used on each side.
    • There is a screw on each of the four sides (top, bottom, and each side) of the face plate. Removing these screws will allow the face plate to be removed from the radio body.
    • There are two types of screws used in this step. The screws on the top and bottom are different from the screws from the sides. Note which style of screw is used on each side.
  9. The face plate can now be removed from the body of the radio.  Gently pull on the face plate to separate it from the radio.  It might require a little bit of wiggling to remove. Be careful when removing the front panel.  The connectors inside are known to have weak solder joints, and it is possible to pull them off of the circuit board.
    • The face plate can now be removed from the body of the radio. Gently pull on the face plate to separate it from the radio. It might require a little bit of wiggling to remove.
    • Be careful when removing the front panel. The connectors inside are known to have weak solder joints, and it is possible to pull them off of the circuit board.
  10. On the right side of the board, there is a screw that goes through a transistor, that secures the control board to the radio.  Remove this screw, and set aside.
    • On the right side of the board, there is a screw that goes through a transistor, that secures the control board to the radio. Remove this screw, and set aside.
    • Remove the screw on the left that holds the board to the radio. Set it aside.
    • The two screws that are removed during this step are not the same. Note which screw comes from which side. The screw with the tapered head goes on the left. The screw with a flat mounting surface goes on the right.
  11. Pull the control board away from the radio body.  It will be slightly more stubborn than the face plate was. There are two connectors that have to be disconnected.  Pull hard enough to separate the connectors, but not hard enough to pull them off of the circuit board.
    • Pull the control board away from the radio body. It will be slightly more stubborn than the face plate was.
    • There are two connectors that have to be disconnected. Pull hard enough to separate the connectors, but not hard enough to pull them off of the circuit board.
结论
Josh
于2013年03月22日注册
626 信誉积分
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 9
过去的30天: 25
总计 2,436
