工具
配件
没有特定配件。
Before doing anything, ensure that the mixer is not plugged in! Then, remove the cover from the high speed attachment. If you don't have this cover, then the low speed attachments will not work anyway, as the cover engages the clutch when it is latched on.
Now, lift the gearbox cover up and towards the front of the mixer - it should slide straight off
Marvel at the decades of ingredients stored safely inside your mixer!
You can remove the belt that drives the gearbox at this point - if this has worn out then only the high speed attachment will have been working. It will lift off nicely with a screwdriver.
The large gear then needs to be gripped, and the "dog" on top of it needs to be removed.
You'll need to hold the gear in place (by holding the bit that grips the K attachment - get someone else to hold onto it tight) and turn the dog with a spanner. Eventually the person holding will feel it release, and you can unscrew the final turn carefully so the spring doesn't fly off!
Apologies for the cake/belt continuity errors in this set - some are taken during reassembly
Hey Josh
Is there a pin or something between the lid and the dog? I can't get the %#*@ thing to engage!
If you just need to remove the large gear, here's the time to do it. You can lift it off with a pair of pliers underneath. Note that this is attached to a plastic gear inside the gearbox and this is the usual failure point if your low speed attachment is not working but your mixer runs.
Next, undo the screws holding the gearbox onto the mixer body. There is one on either side of the mixer (only one shown). If your motor is dead, you may not need to do this.
Next, remove the plastic cover on the bottom of the gearbox. At this point, old crumbs will be getting everywhere. This is held on by four screws, which are removed in the first picture. At this point, you also need to pull the plastic cover off the lever at the front of the mixer.
You now have access to the lower plastic cover - best to give this a wash along with the felt. (picture 2)
Behold the beauty of the Kenwood gearbox (picture 3). Best not to wash this, but remove the 6 screws to gain access.
One thing to do with that - open it up! The cover lifts off showing the still well lubricated gears. Normal failure point ringed - remove this and replace with a new one to fix!
Reassembly is the reverse of dismantling the mixer.
We have one of these old beauties and will never part with it. My only question is, if I take the mixer apart and find I need a part or two, where do I get them from? We live near Gosford NSW. Any ideas will be greatly appreciated. Thank you.
15等其他人完成本指南。
15条评论
Hi I get a slight screeching noise between speed Two and three do you think this is anything to worry about.
The mixer seems perfect at maximum speed.
D MORRIS.
Hi,
I’m not entirely sure, but it sounds like the gearbox (or another part of the drive) may need greasing? The grease can dry up over time and it would lead to that.
Thanks,
Josh
what kind of oil do you use in the gearbox
What type of grease is used in the gearbox (my earlier question was an error)
I’m not sure on the exact spec for the grease, but make sure you get Food Grade grease - it isn’t a sealed unit. Googling Kenwood Food Grade grease finds a few sellers - I can’t remember what I used exactly but it was definitely food grade grease, not kenwood specific though.
Kenwood’s service manual specifies to use 133gr (4 3/4ozs) of Shell L.G.P.1 62814 or Shell L.G.P.1 62819. I was not able to find the specs for this grease. As the separation between the gear box and the food is properly solved I think the use o food grade grease is not mandatory, but I would recommend it anyway. Search for e.g. ‘Food Grade White Lithium EP Grease’. Kenwood Swiss no longer services those machines but the front-desk girl recommended to use just Vaseline - I really doubt about this…
I collected many links to instructionas and spare parts in a youtube playlist: https://www.youtube.com/playlist?list=PL...
There is a variety of kits available that contain grease and other spare parts you might need to repair your Kenwood. It might be a good idea to replace at the same time brushes, resistors and capacitors of the motor.
The service manual recommends to press the grease after reassemly into the gearbox one youtube guy just used a scraper to fill the box before assembly.
Walter, Thanks for adding the service manual spec.
I’d definitely make sure to use food grade grease as the gearbox seal isn’t necessarily perfect. The gearbox on my machine above is full of cake crumbs from over the decades. Also, If you use the anything too viscous it will find its way into the mixing bowl.
Our Kenwood just came to a halt! I have dismantled as you suggest and it appears that the gearbox is OK but the orbital crank pinion has lost a couple of teeth.
It seems to turn ok now but will it do permanent damage if I do not get another pinion?
Peter Cameron
Hi, I have absolutely no power or noise from my A701. I’ve checked the plug fuse. Any ideas?
Hi, mine has done the same - it might be the bushes? I don’t know for sure; we replaced ours. However; it’s up the loft, so if lockdown carries on for much longer, expect a bush replacement guide :)
my planet hub model a701a does not turn when loaded under heavy bread stirring conditions. the drive shaft turns as both low speeds (upper and front) work correctly but the spin loosens the planet nut. the actual problem is the inside f the planet hub hole has been worn larger so that the hub does not engage the flat of the shaft. any ideas where one could get a replacement hub or complete assembly, thanks. enjoyed the vid.
My Kenwood Chef Classic fell off counter but carried on mixing. Cover is slightly scew and beaters dont touch bottom of bowl. Is this easy to fix? Still works.No funny sounds.
Hi, I’m not sure which model I have, but she has a dark blue top. My dough was very stiff, and she now makes a bad noise, kind of ticking. Dough hook still spins. Which part do u think I broke? And how do I work out which model she is please?
Breadmaker - 回复
Hi
I have an kenwood A701A vintage mixer, it is still working but has an electrical burning smell, any ideas what might be wrong
it probably needs a service does anyone do this? For this kenwood mixer
