跳转到主内容
Disassembling KDDI Kyocera A5521K Logic Board
你所需要的
  1. Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: 步骤 1 中的图像 1,3 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: 步骤 1 中的图像 2,3 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: 步骤 1 中的图像 3,3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Logic Board: 步骤 2 中的图像 1,3 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 2 中的图像 2,3 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 2 中的图像 3,3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: 步骤 3 中的图像 1,2 Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: 步骤 3 中的图像 2,2
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K Logic Board: 步骤 4 中的图像 1,2 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 4 中的图像 2,2
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Logic Board: 步骤 5 中的图像 1,3 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 5 中的图像 2,3 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 5 中的图像 3,3
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  6. Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: 步骤 6 中的图像 1,3 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: 步骤 6 中的图像 2,3 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: 步骤 6 中的图像 3,3
    • Rotate the phone approximately 45 degrees to the right.
    • Gently pry up the SD card slot with a spudger.
  7. Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: 步骤 7 中的图像 1,3 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: 步骤 7 中的图像 2,3 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: 步骤 7 中的图像 3,3
    • Lift up on the first connection shown using a pair of pliers.
    • Disconnect the first connection between the logic board and the wire using the pair of pliers.
  8. Disassembling KDDI Kyocera A5521K Logic Board: 步骤 8 中的图像 1,3 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 8 中的图像 2,3 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 8 中的图像 3,3
    • Repeat the above steps for the second connection.
    • Use the pliers to pry up the connection.
    • Use the pliers to disconnect the connection between the logic board and the wire.
  9. Disassembling KDDI Kyocera A5521K Logic Board: 步骤 9 中的图像 1,1
    • Lift up on the bottom of the logic board with a spudger.
    • Gently remove the rest of the logic board from the phone.
  10. Disassembling KDDI Kyocera A5521K Logic Board: 步骤 10 中的图像 1,2 Disassembling KDDI Kyocera A5521K Logic Board: 步骤 10 中的图像 2,2
    • The logic board should now be completely disconnected from the phone.
结论
Dominic Grisafe
于04/15/10注册
157 声望
创作了10篇指南
团队
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G25
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,775
