当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the phone over to expose the battery cover.
Apply pressure to the back of the battery cover to slide it down.
The battery cover is now separate from the phone.
Remove the battery by pushing it up and out from the bottom.
The battery, cover, and phone should now be separated.
Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
Remove the two screws with a Y0 screwdriver.
Rotate the phone 180 degrees.
Carefully separate the back plate from the remainder of the phone.
The back plate should now be detached from the rest of the phone.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
