跳转到主内容
加入维修社区 - 创建账户
Disassembling JVC GR-D290U
你所需要的
  1. Disassembling JVC GR-D290U, JVC GR-D290U: 步骤 1 中的图像 1,2 Disassembling JVC GR-D290U, JVC GR-D290U: 步骤 1 中的图像 2,2
    • Open the liquid-crystal display (LCD) screen.
    • Using a Phillips #1 screwdriver, remove the two hinge screws.
    • Remove the hinge cover. Shut the screen after the cover is removed.
  2. Disassembling JVC GR-D290U: 步骤 2 中的图像 1,3 Disassembling JVC GR-D290U: 步骤 2 中的图像 2,3 Disassembling JVC GR-D290U: 步骤 2 中的图像 3,3
    • Flip the camera over to look at the bottom panel.
    • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
    • Push the eject button beneath the bottom panel to open the cassette cover.
    • Shut the cassette cover.
    • Place the camera upright.
  3. Disassembling JVC GR-D290U: 步骤 3 中的图像 1,1
    • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
    • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
    • Replace the dark gray tab and close the LCD screen.
  4. Disassembling JVC GR-D290U: 步骤 4 中的图像 1,1
    • Go to the side of the camera that is opposite the LCD screen.
    • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
  5. Disassembling JVC GR-D290U: 步骤 5 中的图像 1,2 Disassembling JVC GR-D290U: 步骤 5 中的图像 2,2
    • Go to the side of the camera that has the LCD screen.
    • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
    • Pry the top cover from the bottom cover until you hear a snapping sound.
    • Gently remove the top cover from the camera base.
结论
2等其他人完成本指南。
justin chen
于04/27/10注册
47 声望
创作了3篇指南
团队
Cal Poly, Team 18-69, Johann Spring 2010 Cal Poly, Team 18-69, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G69
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 4,263
