跳转到主内容
Disassembling Insignia NS-B2110 Bottom Panel
你所需要的
  1. Disassembling Insignia NS-B2110 Bottom Panel, Battery: 步骤 1 中的图像 1,2 Disassembling Insignia NS-B2110 Bottom Panel, Battery: 步骤 1 中的图像 2,2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Disassembling Insignia NS-B2110 Bottom Panel: 步骤 2 中的图像 1,2 Disassembling Insignia NS-B2110 Bottom Panel: 步骤 2 中的图像 2,2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Disassembling Insignia NS-B2110 Bottom Panel, Bottom Panel: 步骤 3 中的图像 1,1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Disassembling Insignia NS-B2110 Bottom Panel: 步骤 4 中的图像 1,2 Disassembling Insignia NS-B2110 Bottom Panel: 步骤 4 中的图像 2,2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Disassembling Insignia NS-B2110 Bottom Panel: 步骤 5 中的图像 1,3 Disassembling Insignia NS-B2110 Bottom Panel: 步骤 5 中的图像 2,3 Disassembling Insignia NS-B2110 Bottom Panel: 步骤 5 中的图像 3,3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
结论
Nikki
于10/14/13注册
104 声望
撰写一个指南
团队
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G31
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 214
