跳转到主内容
Disassembling Insignia Flex 8 Circuit Board
你所需要的
  1. Disassembling Insignia Flex 8 Circuit Board, Circuit Board: 步骤 1 中的图像 1,1
    • Turn off the power to your tablet to avoid injury.
    • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
    • Hold down the power button for five seconds until the tablet powers down.
  2. Disassembling Insignia Flex 8 Circuit Board: 步骤 2 中的图像 1,2 Disassembling Insignia Flex 8 Circuit Board: 步骤 2 中的图像 2,2
    • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
    • You may need to use a spudger to initially create separation between the screen and the casing.
    • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
    • Remove the back casing and set aside.
  3. Disassembling Insignia Flex 8 Circuit Board: 步骤 3 中的图像 1,2 Disassembling Insignia Flex 8 Circuit Board: 步骤 3 中的图像 2,2
    • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
  4. Disassembling Insignia Flex 8 Circuit Board: 步骤 4 中的图像 1,3 Disassembling Insignia Flex 8 Circuit Board: 步骤 4 中的图像 2,3 Disassembling Insignia Flex 8 Circuit Board: 步骤 4 中的图像 3,3
    • To remove the camera ribbon cable, lift the flap using a spudger.
    • Pull the ribbon directly back to release it.
  5. Disassembling Insignia Flex 8 Circuit Board: 步骤 5 中的图像 1,3 Disassembling Insignia Flex 8 Circuit Board: 步骤 5 中的图像 2,3 Disassembling Insignia Flex 8 Circuit Board: 步骤 5 中的图像 3,3
    • Remove the second ribbon cable by prying up the black flap using a spudger.
    • Pull the ribbon cable horizontally directly away from the battery.
  6. Disassembling Insignia Flex 8 Circuit Board: 步骤 6 中的图像 1,3 Disassembling Insignia Flex 8 Circuit Board: 步骤 6 中的图像 2,3 Disassembling Insignia Flex 8 Circuit Board: 步骤 6 中的图像 3,3
    • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
    • Pull the ribbon horizontally directly away from the battery.
  7. Disassembling Insignia Flex 8 Circuit Board: 步骤 7 中的图像 1,2 Disassembling Insignia Flex 8 Circuit Board: 步骤 7 中的图像 2,2
    • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
  8. Disassembling Insignia Flex 8 Circuit Board: 步骤 8 中的图像 1,2 Disassembling Insignia Flex 8 Circuit Board: 步骤 8 中的图像 2,2
    • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
    • Lift up the circuit board.
  9. Disassembling Insignia Flex 8 Circuit Board: 步骤 9 中的图像 1,1
    • Unscrew the final two screws that were underneath the circuit board.
    • These screws are near the charging port and USB adapter.
    • These screws are also 3.75mm and can be interchanged with the second set of screws only.
  10. Disassembling Insignia Flex 8 Circuit Board: 步骤 10 中的图像 1,1
    • Lift the circuit board and black internal mounting piece away from the screen.
    • Set the circuit board aside.
    • Be careful of the soldered antenna as you separate the pieces.
    • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
结论
2等其他人完成本指南。
Tyler Tyrrell
于03/11/15注册
890 声望
创作了4篇指南
团队
Colorado Springs, Team 5-5, Panko Spring 2015 Colorado Springs, Team 5-5, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G5
3 名成员
创作了12篇指南
2条评论
Whwre can i buy the new screen
Emmanuel - 回复
I don’t see the ssd, and way to upgrade the internal sad had?
William Henderson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 4,914
