跳转到主内容
Disassembling IBM ThinkPad T42 Rear Cover
你所需要的
  1. Disassembling IBM ThinkPad T42 Rear Cover, Bottom cover: 步骤 1 中的图像 1,1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. Disassembling IBM ThinkPad T42 Rear Cover, Rear screws: 步骤 2 中的图像 1,1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - 回复
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - 回复
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了35篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 4,009
