跳转到主内容
加入维修社区 - 创建账户
Disassembling IBM ThinkPad T42 Plastic Edge Cover
你所需要的
  1. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Bottom cover: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Rear screws: 步骤 2 中的图像 1,1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Keyboard and Trackpad: 步骤 3 中的图像 1,1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. Disassembling IBM ThinkPad T42 Plastic Edge Cover: 步骤 4 中的图像 1,2 Disassembling IBM ThinkPad T42 Plastic Edge Cover: 步骤 4 中的图像 2,2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Plastic Edge Cover: 步骤 5 中的图像 1,2 Disassembling IBM ThinkPad T42 Plastic Edge Cover, Plastic Edge Cover: 步骤 5 中的图像 2,2
    • Starting from the bottom right, carefully remove the bezel by pulling it up gently. If needed use a spudger or flathead screwdriver to help.
结论
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了37篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 32
总计 7,125
