跳转到主内容
Disassembling IBM ThinkPad A30 Modem and Ethernet Cards
你所需要的
  1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: 步骤 1 中的图像 1,2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: 步骤 1 中的图像 2,2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: 步骤 2 中的图像 1,2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: 步骤 2 中的图像 2,2
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  3. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: 步骤 3 中的图像 1,1
    • Remove the four 9.1mm screws attached to the ethernet and modem cards.
  4. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: 步骤 4 中的图像 1,3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: 步骤 4 中的图像 2,3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: 步骤 4 中的图像 3,3
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    • Remove the cables that attach the modem and ethernet cards.
结论
Alan
于10/07/10注册
380 声望
创作了6篇指南
团队
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G44
4 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 2,029
