跳转到主内容
Disassembling IBM ThinkPad A30 CD Drive
  1. Disassembling IBM ThinkPad A30 CD Drive, Battery: 步骤 1 中的图像 1,2 Disassembling IBM ThinkPad A30 CD Drive, Battery: 步骤 1 中的图像 2,2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 CD Drive, CD Drive: 步骤 2 中的图像 1,3 Disassembling IBM ThinkPad A30 CD Drive, CD Drive: 步骤 2 中的图像 2,3 Disassembling IBM ThinkPad A30 CD Drive, CD Drive: 步骤 2 中的图像 3,3
    • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
    • Slide the switch to the right. A black plastic tab will pop out.
    • Pull the plastic tab to expose the CD drive.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
  3. Disassembling IBM ThinkPad A30 CD Drive: 步骤 3 中的图像 1,1
    • Carefully pull the CD drive out from the laptop.
结论
Jessica
于10/06/10注册
162 声望
创作了7篇指南
团队
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G44
4 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 2,560
