跳转到主内容
Disassembling IBM ThinkPad 560z Upper Case
你所需要的
  1. Disassembling IBM ThinkPad 560z Upper Case, Battery Removal: 步骤 1 中的图像 1,1
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Disassembling IBM ThinkPad 560z Upper Case, Upper Case: 步骤 2 中的图像 1,1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  3. Disassembling IBM ThinkPad 560z Upper Case: 步骤 3 中的图像 1,2 Disassembling IBM ThinkPad 560z Upper Case: 步骤 3 中的图像 2,2
    • Open the flap on the left hand side.
  4. Disassembling IBM ThinkPad 560z Upper Case: 步骤 4 中的图像 1,2 Disassembling IBM ThinkPad 560z Upper Case: 步骤 4 中的图像 2,2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  5. Disassembling IBM ThinkPad 560z Upper Case: 步骤 5 中的图像 1,2 Disassembling IBM ThinkPad 560z Upper Case: 步骤 5 中的图像 2,2
    • Open the flap on the right side.
  6. Disassembling IBM ThinkPad 560z Upper Case: 步骤 6 中的图像 1,1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  7. Disassembling IBM ThinkPad 560z Upper Case: 步骤 7 中的图像 1,2 Disassembling IBM ThinkPad 560z Upper Case: 步骤 7 中的图像 2,2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  8. Disassembling IBM ThinkPad 560z Upper Case: 步骤 8 中的图像 1,1
    • Use your fingers or a spudger to detach the connector.
  9. Disassembling IBM ThinkPad 560z Upper Case: 步骤 9 中的图像 1,2 Disassembling IBM ThinkPad 560z Upper Case: 步骤 9 中的图像 2,2
    • Carefully lift and remove the keyboard.
结论
Derek Driscoll
于04/15/10注册
119 声望
创作了8篇指南
团队
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G27
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,729
