跳转到主内容
Disassembling Home Stereo and Theater Philips MCD288
你所需要的
  1. Disassembling Home Stereo and Theater Philips MCD288, Undo screws: 步骤 1 中的图像 1,1
    • remove the 4 screws on the bottem of the main set
  2. Disassembling Home Stereo and Theater Philips MCD288, Expose main latches: 步骤 2 中的图像 1,1
    • Lift the aluminium pane at both sides with a spudger.
  3. Disassembling Home Stereo and Theater Philips MCD288, Start with the bottom edges: 步骤 3 中的图像 1,1
    • To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
    • hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
  4. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: 步骤 4 中的图像 1,2 Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: 步骤 4 中的图像 2,2
    • To detach the sides, pull a main latch towards you and keep on lifting the top part further.
    • repeat for three latches on each side.
  5. Disassembling Home Stereo and Theater Philips MCD288, The inside: 步骤 5 中的图像 1,2 Disassembling Home Stereo and Theater Philips MCD288, The inside: 步骤 5 中的图像 2,2
    • These pictures show the latches on each edge and on the top of the set.
结论
2等其他人完成本指南。
Philipp
于03/16/15注册
71 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 52
总计 7,320
