跳转到主内容
加入维修社区 - 创建账户
Disassembling HTC Incredible 2 Back Panel
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
  1. Disassembling HTC Incredible 2 Back Panel, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 1,2 Disassembling HTC Incredible 2 Back Panel, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 2,2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. Disassembling HTC Incredible 2 Back Panel: 步骤 2 中的图像 1,1
    • Remove the rear panel from the phone.
结论
Jonathan Morsch
于04/26/14注册
394 声望
创作了2篇指南
团队
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G53
5 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 102
