跳转到主内容
Disassembling HP Photosmart c3180 Top Panel
你所需要的
  1. Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: 步骤 1 中的图像 1,2 Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: 步骤 1 中的图像 2,2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Disassembling HP Photosmart c3180 Top Panel: 步骤 2 中的图像 1,2 Disassembling HP Photosmart c3180 Top Panel: 步骤 2 中的图像 2,2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Disassembling HP Photosmart c3180 Top Panel: 步骤 3 中的图像 1,2 Disassembling HP Photosmart c3180 Top Panel: 步骤 3 中的图像 2,2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Disassembling HP Photosmart c3180 Top Panel: 步骤 4 中的图像 1,2 Disassembling HP Photosmart c3180 Top Panel: 步骤 4 中的图像 2,2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Disassembling HP Photosmart c3180 Top Panel: 步骤 5 中的图像 1,2 Disassembling HP Photosmart c3180 Top Panel: 步骤 5 中的图像 2,2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Disassembling HP Photosmart c3180 Top Panel: 步骤 6 中的图像 1,1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Disassembling HP Photosmart c3180 Top Panel: 步骤 7 中的图像 1,2 Disassembling HP Photosmart c3180 Top Panel: 步骤 7 中的图像 2,2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. Disassembling HP Photosmart c3180 Top Panel: 步骤 8 中的图像 1,2 Disassembling HP Photosmart c3180 Top Panel: 步骤 8 中的图像 2,2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Disassembling HP Photosmart c3180 Top Panel: 步骤 9 中的图像 1,1
    • Carefully lift the top panel of the printer away from the printer body.
结论
11等其他人完成本指南。
Jim
于10/06/11注册
1,590 声望
创作了10篇指南
团队
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G30
4 名成员
创作了25篇指南
一条评论
Thanks... Now I'know how clean
Diogo Pires Nunes - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 26
总计 6,486
