当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn off and unplug the netbook before replacing the battery.
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
Slide the battery out from the netbook.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
Pull the back case off from the front edge.
取消:我没有完成这个指南。
12等其他人完成本指南。
与11其他贡献者
于10/06/12注册
723 声望
创作了8篇指南
徽章: 12
+ 9更多徽章
CPSU-AMIDO-F12S9G17
3 名成员
Gracias!! esta guía fue muy util
Tony Ortega - 2014年9月24日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 41
总计 20,895
