跳转到主内容
Disassembling HP Mini 210 Back Case
你所需要的
  1. Disassembling HP Mini 210 Back Case, Battery: 步骤 1 中的图像 1,2 Disassembling HP Mini 210 Back Case, Battery: 步骤 1 中的图像 2,2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. Disassembling HP Mini 210 Back Case: 步骤 2 中的图像 1,1
    • Slide the battery out from the netbook.
  3. Disassembling HP Mini 210 Back Case, Disassembling HP Mini 210 Back Case: 步骤 3 中的图像 1,1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. Disassembling HP Mini 210 Back Case: 步骤 4 中的图像 1,1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. Disassembling HP Mini 210 Back Case: 步骤 5 中的图像 1,1
    • Pull the back case off from the front edge.
结论
12等其他人完成本指南。
Heather Freed
于10/06/12注册
723 声望
创作了8篇指南
团队
Cal Poly, Team 9-17, Amido Fall 2012 Cal Poly, Team 9-17, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G17
3 名成员
创作了8篇指南
一条评论
Gracias!! esta guía fue muy util
Tony Ortega - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 43
总计 20,900
